BUG
Marker symbols export as black when exporting to PDF, EPS, AI and SVG at some resolutions
This issue is addressed with ArcGIS 9.1 Service Pack 2 (SP2)
At some export resolutions, marker symbols export as black when the ArcMap Export option 'Convert Marker Symbols to Polygons' is used. This problem affects PDF, EPS, AI, and SVG export formats.
Cause
This is a known issue.
Workaround
** This issue is addressed with ArcGIS 9.1 Service Pack 2 (SP2) **
Download the Service Pack from the link in Related Information section below.
    Article ID:000008719
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
