Frequently asked question
How does ArcPad interpret the contents of projection (.PRJ) files?
Last Published: February 9, 2024
Answer
ArcPad was retired as of January 1, 2022. As a retired product, there is no new development, patches/bug fixes, or live technical support. Esri has a suite of apps for mobile GIS and field operations. Depending on your use cases and workflows for mobile GIS and field data collection, we suggest that you investigate the capabilities offered by Esri's other mobile apps.
ArcPad stores an internal list of methods and parameters used for transforming coordinates between two datums. When more than one transformation method or set of parameters exists for two datums, ArcPad, by default, uses the first match it finds in this list. The default transformation method ArcPad uses can be overridden by modifying the file defaulttransforms.dbf in ArcPad's System folder.
ArcPad uses .PRJ files to interpret the spatial projection for shapefiles and other data formats. ArcPad examines the contents of .PRJ files and attempts to match values with internal projection tables. If any values are unmatched, the projection may not work correctly in ArcPad.
Consider the contents of the following .PRJ file:
PROJCS["AGD_1966_AMG_Zone_55",
GEOGCS["GCS_Australian_1966",
DATUM["D_Australian_1966",
SPHEROID["Australian",6378160,298.25]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000],
PARAMETER["False_Northing",10000000],
PARAMETER["Central_Meridian",147],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_of_Origin",0.0],
UNIT["Meter",1.0]]
ArcPad interprets this .PRJ as shown in the following illustration:
[O-Image] PRJ File Translation
Article ID:000008675
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
