HOW TO
Rescale raster data
Summary
Instructions provided explain how to rescale values from one raster into a new raster so that the shape (distribution) of the raster's histogram (pixel values) does not change.
The Spatial Analyst extension is needed for ArcGIS to scale the data following the methods listed below.
Procedure
  1. Open the Raster Calculator from the Spatial Analyst toolbar. The Single Output Map Algebra tool can also be used.
  2. Determine the maximum and minimum values used to scale the data.
  3. Use the following equation to scale the grid values:
    Rescaled grid = [(grid - Min value from grid) * (Max scale value - Min scale
    value) / (Max value from grid - Min value from grid)] + Min scale value
    Example 1:
    Scale from 0-255 (8-bit range) to 0-65535 (16-bit range).
    For ArcGIS 9.x
    [O-Image] Example 1 - 9.x
    For ArcGIS 10.x
    [O-Image] Example 1 - 10.x
    Example 2:
    Scale from 0-65535 (16-bit range) to 0-255 (8-bit range).
    For ArcGIS 9.x
    [O-Image] Example 2 - 9.x
    For ArcGIS 10.x
    [O-Image] Example 2 - 10.x
    Example 3:
    Scale from range of 0-255 to range of 100-200.
    For ArcGIS 9.x
    [O-Image] Example 3 - 9.x
    For ArcGIS 10.x
    [O-Image] Example 3 - 10.x
Article ID:000008671
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
