English
How To: Export a model to a graphic
Summary
Instructions provided describe how to export a model from ModelBuilder to a graphic or image file in Windows bitmap (.bmp), JPEG Image (.jpg), or Enhanced Metafile (.emf) format.
Procedure
Follow the steps below:
  1. Right-click the desired model in ArcToolbox and click Edit.
  2. On the Model menu, click Export > To Graphic.
    [o] export model to graphic
  3. In the Save As Image dialog box, select the following:
    • Under Image, select a graphics file format from the Type drop-down menu
    • Under Image Characteristics, set the image quality
    • Under Size, select the graphic's extent
  4. Under Image, type the path and the file name or click the Browse button and browse to a location to save the graphic and type a file name.
  5. Click OK.
Related Information
