ERROR
When using ArcPress for ArcInfo Workstation on the DOS command line or prompt, the following error is displayed:
"Invalid pagesize"
This occurs when the pagesize (-P:<x,y>) flag has been entered incorrectly, especially when the y value is missing.
This can also occur in local environments that use the opposite decimal and digit grouping symbols than English, causing an incorrectly formatted -P:<x,y>.
Format the x,y page coordinates to follow the OS decimal and digit grouping symbol. You may need to include an additional ',' to differentiate the x value from the y value.
For example, if the page size is 80,5cm x 123,7cm, then the x,y coordinates should be:
-P:80,5,123,7
-P:80,,123,7
Remember that when using a period '.' as the digit grouping symbol, applying the ArcPress flag for changing units (-u:<upi>), using -u:2.54 will not convert the units to centimeters but rather set the 1" to equal 254 units! Be sure to set the units per inch flag like this:
-u:2,54
Get help from ArcGIS experts
Download the Esri Support App
