English
Bug: Error: 'Cannot determine DBMS release' when running sdesetupora9i with Oracle 10g R2
This issue is addressed in ArcSDE 9.1 Service Pack 1 (SP1).
When running sdesetupora9i -o install -u SDE -p xxxxx
for ArcSDE 9.1 for Oracle 10g R2, the following error may get returned:
ESRI ArcSDE Server Setup Utility
db_get_dbms_release:: Invalid Release (10.2.0.1.0)
Cannot determine DBMS release using SDO_ADMIN.sdo_version function.
Cause
ArcSDE 9.1 is not supported with Oracle 10g R2. There is a known issue that prohibits it from connecting to Oracle 10g R2 databases.
Workaround
A fix included in ArcSDE 9.1 Service Pack 1 will allow the connection. Download the pack using the link in Related Information, below.
    Related Information
