English
Error: ESRI ArcPad 7.0 does not support the connected device type
Error Message
When installing a purchased upgrade of ArcPad 7.0, the following error message may occur:
"ESRI ArcPad 7.0 does not support the connected device type. Application Manager will make the application available for installation when a supported device type is connected."
Cause
ArcPad 7.0 is being installed on a device that is run by an operating system that doesn't support ArcPad.
Solution or Workaround
Please see the Systems Requirements link in Related Information, below.
    Related Information
