English
Error: Undefined Symbol __floorf __fabsf
Error Message
When compiling customized applications with the 9.2 ArcSDE C API on Sun Solaris 9, the symbols '__floorf' and '__fabsf' error as undefined by the C compiler:
"Undefined Symbol __floorf __fabsf"
Cause
The computer does not have the required Solaris patch level installed, 111722-04 or higher. The symbols '__floorf' and '__fabsf' are defined in the operating system library file libm.so.
Solution or Workaround
  1. Check the version of the libm.so file, execute the following command:
    Code:
    what /usr/lib/64/libm.so | grep VERSION
  2. Install the Solaris patch 111722-04 or higher.
