English
How To: Select a bar code font
Summary
Some map products require bar code fonts. These fonts are standard fonts that must meet bar code reader requirements. Because of this, there are many fonts available from different sources. The product requirements should outline the required type of bar code font.
Procedure
Most bar code fonts are available on the web by simply searching for the type of font required. For example, code 39 bar code font is available from many venders, all of which may be appropriate for your product.
