English
Problem: Missing tabs in Layer Properties window
One or more tabs may be missing from the Layer Properties window in ArcMap, ArcGlobe or ArcScene.
Cause
ArcScene.exe, ArcGlobe.exe or ArcMap.exe did not properly register during installation or they became unregistered.
Solution or Workaround
Below are steps to perform depending on the application that is missing tabs.
ArcMap
1. Close ArcMap
2. Click Windows Start menu
3. Select Run
4. Enter the text as:
"C:\Program Files\arcgis\bin\ArcMap.exe" /regserver
5. Click 'OK'
6. Relaunch ArcMap
ArcScene
1. Close ArcScene
3. Select Run
"C:\Program Files\arcgis\bin\ArcScene.exe" /regserver
5. Click 'OK'
6. Relaunch ArcScene
ArcGlobe
1. Close ArcGlobe
3. Select Run
"C:\Program Files\arcgis\bin\ArcGlobe.exe" /regserver
5. Click 'OK'
6. Relaunch ArcGlobe
