ERROR
System.Exception: Unable to clone page layout
Error Message
The following error may occur when the user tries to create a map series by using MPS Atlas:
"System.Exception: Unable to Clone the page layout ---> System.Exception: Unable to clone source ---> System.Exception: Unable to save Object ---> System.Exception: Exception from HRESULT: 0x80131500.
at ESRI.ArcGIS.esriSystem.ObjectStreamClass.SaveObject(Object pUnk)
at PLTS.Engine.Lib.PersistStreamHelper.SaveObject(IStream ipStream, IPersist ipPersist)
--- End inner exception stack trace ---
at PLTS.Engine.Lib.PersisStreamHelper.SaveObject(IStream ipStream, IPersist ipPersist)
at PLTS.Engine.Lib.PersisStreamHelper.SaveObjectSafely(IStream ipStream, IPersis ipPersist)
at PLTS.Engine.Lib.CloneHelper.Clone(IPersist ipSource)
at Atlas.Utilities.Utilities.ClonePageLayout(IPageLayout ipPageLayout)
at Atlas.Utilities.ClonePageLayout(IPageLayout ipPageLayout)
at Atlas.UI.Wizards.CreateMapSeriesWizard.Show(IPllication ipApp)"
Cause
The machine running PLTS MPS Atlas has a version of Microsoft Data Access Components (MDAC) that is version 2.5 or earlier. MDAC needs to be updated to version 2.6 or greater.
Solution or Workaround
Download and install the latest version of MDAC from Microsoft and install it on the PLTS machine. Refer to the link in Related Information below.
    Article ID:000008413
    Software:
    • ArcGIS Production Mapping
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
