English
Error: Error Call Stack Sequence - GetEditStatus clsOPP.cls
Error Message
Installing the ESPN Motion Runtime Utility prevents ArcGIS Desktop from accessing AutoCAD drawing files (DWG) and AutoCAD export files (DXF), which displays the following error message:
"Error Call Stack Sequence - GetEditStatus clsOPP.cls"
Cause
Installation of this viewer conflicts with ArcGIS ability to access CAD files.
Solution or Workaround
  1. Navigate to Start > Programs > Control Panel > Add and Remove Programs, and uninstall the ESPN Motion Runtime Utility. If 'OPP' is listed, also uninstall that program.
  2. Reboot the computer.
