English
Problem: The raster dataset displays as solid black
Raster datasets may appear as solid black when displayed in ArcGIS Desktop. It is also possible to have this problem with raster datasets within a raster catalog; they may also appear as solid black when displayed in ArcGIS Desktop.
Cause
This can be caused by missing raster statistics. Statistics allow ArcGIS to properly contrast stretch a raster dataset. If the statistics are not calculated, then no contrast stretching can be used, sometimes making the raster dataset appear completely black.
Solution or Workaround
Build statistics for the raster datasets.
When experiencing this problem with a raster catalog, calculate statistics for each raster dataset item in the raster catalog; it is not possible to calculate statistics on the catalog itself.
  1. In ArcCatalog, right-click on the raster dataset and click Calculate Statistics.
  2. In the Calculate Statistics dialog box, set the skip factor and the ignore value and click OK.
Related Information
