BUG
Identify tool does not show attribute values of an integer raster with more than 256 unique values
Last Published: May 6, 2020
An ESRI GRID can have several columns in its value attribute table (VAT). When performing an Identify on a raster in ArcMap, which is using a Stretched renderer, the Identify window returns the value of the pixel, its stretched value, and the attribute information. However if there are more than 256 unique values, the attribute information is not shown.
Cause
By design, the Identify tool returns true pixel values as well as values after rendering, which translates to what is displayed on the map. ArcMap displays a raster, which has a table of more than 256 values, with a Stretched renderer by default, and Identify returns a pixel value and stretched value.
Workaround
To identify all the attribute information in the table, change the renderer to a unique value renderer before performing an Identify. Refer to ArcMap: Drawing thematic raster datasets representing unique categories for more information.
Article ID:000008385
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
