PROBLEM
After installing a Service Pack for ArcIMS, unable to add additional components from the original installation CD
An error message similar to the following is displayed when attempting to add additional features by running the setup.exe from the original installation CD after having installed a service pack for ArcIMS:
"ArcGIS ArcIMS Version 9.1.750 is already installed. You must uninstall the existing version before installing ArcGIS ArcIMS Version 9.1.722. Do you want to uninstall the existing version of ArcGIS ArcIMS"
Cause
When a service pack is installed, the build number of ArcIMS is updated in the Windows Registry. The MSI installer checks this build number against the original CD as they need to match in order to add additional features.
Solution or Workaround
Use the following procedure to add additional components:
  1. Navigate to Start > Settings > Control Panel > Add or Remove Programs, select ArcGIS ArcIMS in the list, and click the 'Change' button.
  2. Install additional features as needed.
    Depending on what additional components are added, reapply the service pack. Check the documentation for the service pack to see what files were updated.
Article ID:000008376
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
