English
Bug: Return error SE_LOST_DBMS_Connection(-409) to ArcIMS when a dbms is shutdown or when a session is not available
** This issue is addressed in ArcIMS 9.1 Service Pack 1 (SP1) **
Currently, the ArcIMS spatial server is designed to reconnect to ArcSDE when a network I/O error -10 is returned.
When a session is killed in Oracle, spatial server gets:
[Sep 7, 2005 2:14:40 PM][3840 3888 ERROR] [ERR2407] (SDE error code -51 ) SE_stream_fetch : Underlying DBMS error
[Sep 7, 2005 2:14:40 PM][3840 3888 ERROR] ORA-01012: not logged on
When Oracle is shutdown and features are requested, the error message returned is:
[Sep 7, 2005 2:57:38 PM][3840 3888 ERROR] [ERR2407] (SDE error code -51 ) SE_stream_fetch : Underlying DBMS error
[Sep 7, 2005 2:57:38 PM][3840 3888 ERROR] ORA-03114: not connected to ORACLE
In both the above situations, the spatial server will not attempt to reconnect, but no error message is displayed.
Cause
This is a known issue.
Workaround
The return error SE_LOST_DBMS_Connection(-409) to ArcIMS displays when a dbms is shutdown or when a session is not available.
    Related Information
