BUG
WMS Connector does not return error message when unsupported SRS is requested
When sending a WMS request, ArcIMS will return an error message if the Spatial Reference System code (SRS) is not recognized. At ArcIMS 9.1 Service Pack 1 the error message is "Invalid SRS Value."
This sample Capabilities File fragment and the following GetMap request may cause such a problem.
Capabilities File fragment:
Code:
<Layer queryable="0" opaque="0" noSubsets="0">
<Name>wmstest</Name>
<Title>wmstest</Title>
<SRS>EPSG:4326</SRS>
<SRS>EPSG:4327</SRS>
<LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>
Request:
Code:
http://myserver/wmsconnector/com.esri.wms.Esrimap/wmsservice
?service=WMS
&request=GetMap
&Layers=wmstest
&Styles=
&Version=1.1.1
&SRS=EPSG:4328
&BBOX=-180,180,-90,90
&width=400
&height=300&
EPSG:4328 is not listed in capabilities file, therefore an error exception will be returned:
Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
Invalid SRS value
</ServiceException>
</ServiceExceptionReport>
Cause
In WMS, a Spatial Reference System (SRS) is a text parameter that specifies a horizontal coordinate reference system code. When a WMS GetMap request is issued with an SRS value not listed in the WMS Capabilities file, the WMS Connector returns an exception stating it has encountered an invalid SRS.
Workaround
Before sending GetMap requests to WMS Service, make sure that the SRS value you request is listed in that WMS Service's capabilities file. WMS Connector doesn't support any SRS values that are not listed in capabilities file.
    Article ID:000008313
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
