BUG
Incorrect query results when data contains many wide columns
When service data contain very wide columns, such as many columns of type VARCHAR(8000), a SPATIALQUERY may return records successfully, but only for a limited number of such fields. Beyond that number, the Spatial server returns '0' records. This is an incorrect result and is being investigated as a bug.
For example, a query with a valid ‘where’ clause and subfields="#ID# #SHAPE#" returns N records. It will continue to return N records as more columns are added to ‘subfields’. This is an example of the request:
Code:
<ARCXML version="1.1">
<REQUEST>
<GET_FEATURES featurelimit="25" beginrecord="0" outputmode="xml" geometry="false" envelope="true" >
<LAYER id="0" />
<SPATIALQUERY subfields="#ID# #SHAPE# FIELD_1 FIELD_2 WIDEFIELD_3 " where="TEST.TEST.DISTRICT.TEAMS > 2" >
</SPATIALQUERY>
</GET_FEATURES>
</REQUEST>
</ARCXML>
This is the output from the QueryServer:
Code:
<ARCXML version=”1.1”>
<RESPONSE>
<FEATURES>
<FEATURECOUNT count=”5” hasmore=”false” />
</FEATURES>
</RESPONSE>
</ARCXML>
However, a limit will be reached where the query works with 10 subfields columns, but it fails with 11+ columns in the list. Here is an example of the request:
Code:
<REQUEST>
<LAYER id="0" />
<SPATIALQUERY subfields="#ID# #SHAPE# FIELD_1 FIELD_2 WIDEFIELD_3 WIDEFIELD_4 WIDEFIELD_5 WIDEFIELD_6" where="TEST.TEST.DISTRICT.TEAMS > 2" >
</SPATIALQUERY>
</GET_FEATURES>
</REQUEST>
</ARCXML>
And this is the reponse:
Code:
<RESPONSE>
<FEATURES>
<FEATURECOUNT count=”0” hasmore=”false” />
</FEATURES>
</RESPONSE>
</ARCXML>
A SPATIALQUERY with subfields=”” or subfields=”#ALL#" also returns 0 records.
Cause
Although the created tables use columns of extreme width, it is also possible that certain view-creation transactions and other SQL commands (such as 'replace'), may inadvertently cause columns to become the varchar(8000) data type.
Workaround
Remove or alter such columns so that they are only as wide as necessary for the anticipated record values.
    Article ID:000008308
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
