HOW TO
Find the session log file tables in tempdb of a SQL Server DBMS
Summary
Instructions provided describe how to view the session log file tables in the temporary database (tempdb) of a SQL Server DBMS.
Procedure
The recommended log file configuration for ArcSDE for SQL Server is session-based log file tables created in tempdb. To find the names of the log file tables, execute a query in tempdb to return a list of the tables located there.
Execute the following query from a query window in the Query Analyzer or Management Studio:
Code:
USE tempdb
SELECT * FROM information_schema.tables
The returned list of tables includes table names, their types, and the names of the schemas in which the tables reside. The session-based log file table names will follow this format in ArcSDE 9 through 9.3.1: ##SDE_session<sde_id>. In ArcSDE 10.x, the format is ##SDE_session<sde_id>_<database_id>.
Temporary objects do not show up in Enterprise Manager or the Object Explorer in Management Studio; therefore, the query shown above must be executed to see these tables.
Article ID:000008284
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
