HOW TO
ArcWeb uses styles to determine how features appear on a map. This article describes how to rename an ArcWeb Services style.
· Select the Edit tab of a layer or map service in the Content Library Click the layer or map service title to access the Edit tab.
Other notes:
· Enter a new name for an ArcWeb style in the Modify Style dialog box and a copy of the style is created with the new name. This style appears with custom content in the Content Library.
· Enter a new name for a style that you own in the Modify Style dialog box and the style is renamed.
When a style that you own is renamed, the old style is overwritten. This means any references to the old style break. If there is a broken style reference in Edit Map, the layer reverts to using its default style. If there is a broken reference in Edit Layer, the layer reverts to using the ArcWeb default style for that style type. The default styles are: point - black circle; line - black line; poly - green poly; label - Arial 10 pt.
Get help from ArcGIS experts
Download the Esri Support App
