English
Problem: Cannot use the 'Cut Polygons without Selection Task' sample or register CutPolygonsTask.dll
Problems occur when using the 'Cut Polygons without Selection Task' sample. The following error may display when adding and/or registering the CutPolygonsTask.dll:
"No new objects added"
This sample is located in C:\Program Files\ArcGIS\DeveloperKit\samples\Editing after the ArcGIS Desktop Developer Kit has been installed.
Cause
The operating system is missing msjava.dll.
Solution or Workaround
Verify that the computer is up-to-date with Microsoft Windows Update.
    Related Information
