English
Error: Open Failed. Error opening feature class. General Function Failure
Error Message
Adding data into ArcMap returns the following error:
"Open Failed
General Function Failure"
Cause
In ArcGIS 8.x, this can occur due to known issues with renaming the feature class name. The following methods may corrupt the feature class name and table:
1. Selecting the name and modifying it.
2. Right-clicking on the name and selecting Modify in ArcCatalog.
Solution or Workaround
For ArcGIS 8.x, use the following solution:
If the data is not a geodatabase feature class, export it to a geodatabase. This forces the name and table to be set properly.
This problem has been resolved for 9.x.
