English
How To: Create two address locators with different zone values using the same reference data
Summary
Instructions provided describe how to create multiple address locators with different zone values using the same reference data.
Procedure
This example procedure describes how to create address locators using ZIP code and City for the same reference data.
When finished, either the ZIP or City can be entered in the Zone field in the Find Address dialog box using the composite locator.
  1. Copy and paste the file 'US Streets with Zone (GDB).lot' in <ArcGIS_install_location>\Locators folder to make a copy of it. Rename the copy to another name such as 'US Streets with City (GDB).lot'.
  2. Open 'US Streets with City (GDB).lot' in a text editor such as Notepad.
  3. Replace the following line:
    Code:
    RD.IdxTable1.Prefix = GC_SZS
    with
    Code:
    RD.IdxTable1.Prefix = GC_SZC
    Save the file.
  4. Start ArcCatalog and create the two address locators using the 'US Streets
    with Zone (GDB).lot' and 'US Streets with City (GDB).lot' styles.
    ArcCatalog creates two indexes tables, one with ZIP and one with City, as the zone fields.
  5. Create a composite locator for the multiple locators.
