English
Bug: Failed to compress database. Invalid SQL syntax
** This issue is addressed in ArcSDE 9.1 Service Pack 1 (SP1) **
When running the sdeversion –o compress command and there are more than 150 states in attempting to trim back to base, the following parse error occurs:
"Failed to compress database. Invalid SQL syntax [SDE.default]."
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcSDE 9.1 Service Pack 1 (SP1).
Click on the link in Related Information below to download the Service Pack, if necessary. **
    Related Information
