English
Bug: 'Select from current selection' does not work
** This issue is addressed in ArcSDE 9.1 Service Pack 1 (SP1) **
When you select records from an existing selection set in ArcMap using the 'Select from current selection' method in the 'Select By Attributes' command window, all of the selected records are cleared. This occurs if the selection is made against data stored in an ArcSDE for SQL Server 2000 geodatabase.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcSDE 9.1 Service Pack 1 (SP1).
Click on the link in Related Information below to download the Service Pack, if necessary. **
    Related Information
