English
How To: Enable and disable ArcInfo Workstation extensions
Summary
This article includes information on how to enable and disable ArcInfo Workstation's extensions. Use this when a license must be released to the available pool so that other users may access it.
Procedure
Use the PRODUCT command at the Arc prompt to enable or disable the extension.
  • Type the following command at the Arc prompt to ENABLE an extension:
    PRODUCT <PRODUCTNAME> AVAILABLE
    For example:
    Code:
    PRODUCT GRID AVAILABLE
  • Type the following command at the Arc: prompt to DISABLE an extension, releasing the license to the shared pool:
    PRODUCT <PRODUCTNAME> DISABLED
    For example:
    Code:
    PRODUCT GRID DISABLED
    This will cause the product to give a licensing error when an attempt is made to start it:
    Code:
    You are not licensed for Grid - GRID not run.
