English
FAQ: Where does the ArcSDE geocoding processing occur?
Question
Answer
If the Address Locator, reference data and the address table are all stored on the ArcSDE server, then the processing occurs on the server.
If any one of the above mentioned objects is not stored in the ArcSDE geodatabase, or if the user is making a Direct Connection to the database, then the processing occurs on the client machine.
