English
Bug: Network Dataset Properties shows as Empty for ArcSDE network datasets
In a network dataset in an ArcSDE geodatabase, the Network Dataset Properties dialog's General tab shows the status of the network dataset as being Empty. Rebuilding the network dataset does not change the status.
Cause
The Network Dataset Properties dialog is displaying incorrect information about the network dataset's status.
Workaround
The Status box on the Network Dataset Properties dialog can be ignored for a network dataset in an ArcSDE geodatabase.
If unable to determine whether the network dataset has been built after making the latest edits, then build the network dataset.
