English
Error: AXL Project File: Data Cannot Be Found. Check Connections and Retry
Error Message
The ArcIMS Java Viewer returns the following error:
"AXL Project File: Data Cannot Be Found. Check Connections and Retry."
Cause
This is usually caused when using the Microsoft IIS6 web server on a Windows 2003 machine.
The web server is missing the MIME type for the extension '.AXL'. It is not able to load the default.axl file which includes all the information about the data that needs to be loaded in the Java Viewer.
Solution or Workaround
For the procedure on how to enable the MIME type .AXL, please see the article linked in the Related Information section below.
    Related Information
