BUG
GET_GEOCODE request for Route Server returns no results due to incorrect GCTAG id
When using the SDC.STREET_ADDRESS.CAN address style with data from DMTI, the documentation indicates to use the GCTAG of id="Street_or_Intersection" for input street addresses with a GET_GEOCODE request. While this request is valid, no features will be returned.
Cause
This is due to an error in the RouteServerGeocodingStyles.pdf.
Workaround
The solution to this issue is to use GCTAG id="Address_or_Intersection" for requests. For example:
Code:
<ARCXML version="1.1">
<REQUEST>
<GET_GEOCODE maxcandidates="20" minscore="50">
<LAYER id="StreetAddress" /><ADDRESS>
<GCTAG id="Address_or_Intersection" value="49 Gervais Dr"/>
<GCTAG id="FSA" value="M3C"/>
<GCTAG id="City" value="Toronto"/>
<GCTAG id="Province" value="ON"/>
</ADDRESS>
</GET_GEOCODE>
</REQUEST>
</ARCXML>
This will return positive results. While the following request will return no results:
Code:
<REQUEST>
<GCTAG id="Street_or_Intersection" value="49 Gervais Dr"/>
</ADDRESS>
</GET_GEOCODE>
</REQUEST>
</ARCXML>
    Article ID:000008115
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
