English
Problem: Line widths or text sizes are incorrect in ArcMap created AI files
Line widths or text sizes are incorrect in ArcMap-created Adobe Illustrator (.AI) files.
Cause
The output resolution of the .AI file from ArcMap is not divisible by 72.
Solution or Workaround
The AI exporter works best in resolutions divisible by 72. Export to the .AI format in a DPI that is divisible by 72; for example, 360, 720, and so forth.
    Related Information
