PROBLEM
Norton SystemWorks WinDoctor disables ArcGIS
Running the Norton SystemWorks 2005 WinDoctor module with 'Fix Errors' enabled causes ArcGIS to stop working.
Cause
The WinDoctor module with 'Fix Errors' enabled removes several ArcGIS registry entries and corrupts the application.
Solution or Workaround
Do not use WinDoctor with Norton SystemWorks.
If the WinDoctor module with 'Fix Errors' enabled has already been run, repair the ArcGIS installation.
  1. To repair the ArcGIS installation, insert the ArcGIS Desktop, ArcView or ArcEditor CD into the computers CD-ROM drive.
  2. Select Install ArcGIS Desktop and click Next.
  3. Select Repair and click Next.
Article ID:000008101
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
