Answer
Wildcard characters, such as the percentage mark (%), asterisk (*), underscore (_), or question mark (?), can be used in a spatial query when using the LIKE operator.
If using a shapefile in the Image server use % as the wildcard for zero or more characters and use ? as the wildcard for a single character.
If using ArcSDE features in the Image server use % as the wildcard for zero or more characters and use _ as the wildcard for a single character.
If using shapefile or ArcSDE features in ArcMap server use, % as the wildcard for zero or more characters and use _ as the wildcard for a single character.
If using personal geodatabase in ArcMap server, use * as the wildcard for a group of characters and use ? as the wildcard for single character.
Use of ESCAPE does not work with a wildcard query.
