BUG
The Thematic template in the .NET ADF allows the user to open the Classify dialog when there are no layers available to classify in the server object. Clicking OK to the Classify dialog displays a 'Loading' message and gives the appearance that the application is busy.
This is a known problem with the Thematic template when the server object does not contain layers which can be classified.
Get help from ArcGIS experts
Download the Esri Support App
