ERROR
Run-time error "-2147467259 (80004005) Automation error Unspecified error
Error Message
The following error message is displayed when using Coverage to Geodatabase:
Automation error
Unspecified error"
This was due to a corrupt coverage.
Cause
This is a known issue, CQ00073588.
This can occur with a corrupt coverage in ArcMap 8.3.
Solution or Workaround
Export the coverage as an .E00 file and import it back into ArcMap.
  1. Start ArcToolbox and navigate to Conversion Tools > Export From Coverage > Export To Interchange File to export the coverage as an .E00 file.
  2. Navigate to Conversion Tools > Import to Coverage > Import from Interchange File to import the .E00 file to coverage format.
Article ID:000008042
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
