English
FAQ: Can ArcIMS Metadata services be created with ArcSDE direct connect?
Question
Answer
Yes, an ArcIMS Metadata service can be created with an AXL using ArcSDE direct connect.
Here are the steps to set a direct connect using ArcSDE with Oracle:
How to create a direct connect from ArcIMS to ArcSDE/Oracle
Here are the steps to set a direct connect using ArcSDE with MS SQL Server:
Create a direct connect from ArcIMS to ArcSDE for SQL server
