BUG
Java Connector: Cannot use an encrypted password with a dynamically generated SDEWORKSPACE
An application using the Java Connector returns the following or similar error when attempting to dynamically add an SDEWORKSPACE with an encrypted password.
Code:
Underlying input stream returned zero bytes
File "null" not found
null
Cause
The encrypted attribute is not added to the SDEWORKSPACE tag in the GET_IMAGE request sent to ArcIMS. As a result of the default value for the encrypted attribute ("false"), the password is not decrypted, and ArcSDE server authentication fails.
Workaround
The only Java Connector supported workaround is to use basic, unencrypted password when creating a new SDEWORKSPACE.
    Article ID:000008021
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
