ERROR
Failed to delete a domain from the database
Error Message
The content in this article pertains to ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Deleting a domain from a geodatabase results in one of the following errors:
"Failed to delete a domain from the database.
The domain is used as a default domain."
or,
The domain is used by an attribute rule."
Cause
These errors occur if the domain is applied to one or more fields in the geodatabase.
Solution or Workaround
To delete a domain, it must not be associated with any fields in the geodatabase.
For information regarding how to associate and disassociate domains from fields, refer to the ArcGIS Desktop Help.
  • In 9.1,  navigate to Building a geodatabase > Subtypes and attribute domains > Associating default values and domains with feature classes and tables.
  • In 9.2, navigate Geodatabases and ArcSDE > Building a Geodatabase > Working with geodatabase datasets > Domains > Associating default values and domains with feature classes and tables.
Article ID:000008003
Software:
  • ArcMap 8 x
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
