Frequently asked question
Which X Window components must be installed for ArcGIS Server on Linux and Solaris?
Answer
The following are the OS packages that include the required X-Window components:
ArcGIS Server on Suse Linux:
· Graphical Base System
ArcGIS Server on Red-Hat Linux:
· Base Development package
· Base Legacy Software Development package
ArcGIS Server on Solaris 9:
· X Window System & Graphics Header links in /usr/include 2.6.0
· X Window System & Graphics Runtime Library Links in /usr/lib 2.6.0
· X Window System Display Postscript CID support library 8
· X Window System ICE library (64-bit) 3.5.0
· X Window System Internationalization Common Package 6.0.0
· X Window System Internationalization Common Package (64-bit) 6.0.0
· X Window System Minimum Required Fonts for Multibyte Locales 1.0
· Chinese/Taiwan BIG5 X Windows Platform minimum required Fonts
· Japanese X Window System Minimum Required Fonts 5.8
· Japanese X Window System common fonts 2.8
· Korean UTF-8 X Windows Platform minimum Required Fonts 8_asia_
· Simplified Chinese (EUC) X Windows Platform minimum Required F
· X Window System Runtime Compatibility Package (64-bit) 3.5.0
· X Window System X Input Method Server Package 5.0.0
· X Window System X Input Method Server Package (64-bit) 5.0.0
· X Window System library software (64-bit) 3.5.0
· X Window System lint libraries (64-bit) 3.5.0
Article ID:000007985
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
