HOW TO
Create a hillshade or slope using data in Geographic coordinates
Summary
When performing a hillshade or slope function in ArcGIS, the Z units are presumed to be the same as the horizontal (x,y) units. When working with data in geographic coordinates, this is a problem because the linear distance of a degree of latitude varies.
In some cases, a value of 0.000003 was suggested as the Z factor to account for the actual Z unit in meters. While that value can still be used, this article presents a more accurate method of determining the Z factor when the Z units are in meters.
Procedure
The following procedure assumes the Z units of the raster being used to generate the hillshade or slope are meters. If the Z units of the data being used are feet, first use the raster calculator to multiply the raster by the conversion factor 0.3048, so that the z units are meters.
  1. Determine what the middle latitude of the area of interest is.
  2. Convert that degree value to radians.
    1 degree = 0.0174532925 radians
  3. Use the value in radians in the following equation:
    Z factor = 1.0 / (113200 * cos(<input latitude in radians>))
  4. Use this calculated Z factor in the hillshade or slope tool.
Article ID:000007956
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
