BUG
Map elements or data frame in layout move or shrink when printed or exported
Some or all map elements or objects, including data frames, shrink or move when printed or exported.
Cause
While there can be several reasons for this, the data frame percentage setting is a known issue.
Workaround
Change the percentage setting for the data frame.
  1. Right-click on the data frame in ArcMap Layout and select Properties.
  2. Click on the Size and Position tab.
  3. Change the state of the As Percentage check box and click OK.
    There can be several causes to problem and this workaround may not resolve the issue for every map.
Article ID:000007937
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
