English
Problem: The font size in an ArcIMS ArcMap Service is out of focus and small
When viewing an ArcIMS ArcMap image service, for example, in an HTML Viewer or ArcMap, the fonts are displayed out of focus and too small.
Cause
The display settings on the ArcIMS Server machine need to be reset.
Solution or Workaround
The problem may involve hardware - check the monitor and also the video card drivers and, if possible, upgrade to higher resolution hardware.
Follow the steps below.
  1. Select the Settings tab in the Control Panel access display and set the Screen Area to 1600 X 1200.
  2. Click on the Advanced button and set Font Size to Large Fonts.
    If ArcMap and ArcIMS are installed on separate computers, these settings should match on both computers.
