English
Bug: Black text set as C=0 M=0 Y=0 K=100 renders as composite black
Symbology and text may render as composite black C=100 M=100 Y=100 K=100 instead of pure black C=0 M=0 Y=0 K=100 in some graphics-, pre-flight- or rasterizer applications.
Cause
This is a known issue.
Workaround
There are two possible workarounds.
  • Set the text to a color not used in the map, such as bright magenta. When sending the print job to a print shop, instruct them to exchange the bright magenta with pure black C=0 M=0 Y=0 K=100 during pre-flight.
    While some raster-based graphic and pre-flight applications show this black text as composite black, Adobe Illustrator should display the black text correctly when viewing ArcMap 8.x created PDF, EPS and AI files.
  • Upgrade to ArcGIS 9.0 or higher. The output destination colorspace can be set to CMYK when exporting to PDF, EPS or AI files.
    [O-image] ArcMap PDF colorspace setting
    Ensure Service Pack 2 or higher is installed for best results from these exporters.
