BUG
Microsoft's Sharepoint does not start when ArcGIS Server .NET Application Development Framework (ADF) is installed on the same machine. This occurs with ArcGIS Server .NET ADF versions 9.0 and 9.1.
This is caused by the setup of an ASP.NET HTTP Handler for streaming images from ArcGIS Server.
Code:
<add verb="*" path="ESRI.Web.Controls.MIMEImage.aspx"
type="ESRI.ArcGIS.Server.WebControls.ImageHandler,
ESRI.ArcGIS.Server.WebControls, Version=9.0.0.4, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86"/>
Code:
ESRI.ArcGIS.Server.WebControls, Version=9.1.0.722, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86" validate="false" />
Get help from ArcGIS experts
Download the Esri Support App
