English
How To: Test ArcIMS 9.x to ensure map services can be created with sample data
Summary
The document contains information on how to test the ArcIMS Spatial Server to ensure it is working correctly, and is able to create simple map services using sample data.
Procedure
Follow the platform specific procedure for creating ImageServices and ArcMap Services.
  • Windows
    1. Download the Windows Sample Data and Map Configuration Files (AXL and MXD) from the following location: Download samplewin.zip
    2. Extract sample files.
      1. Navigate to the temporary location where samplewin.zip was downloaded.
      2. Use WinZip to extract the contents to the root of C:
    3. Create an ImageService from a sample *.AXL file.
      1. Navigate to Start > Programs > ArcGIS > ArcIMS > Administrator and start the ArcIMS Administrator.
      2. Click on Services
      3. Click on the button to create a new service
      4. Fill in the information as listed below:
        Map File: c:\test_win.axl
        Virtual Server: ImageServer
        Image Type: JPEG
        Directory Location: C:/ArcIMS/Output
        HTTP Location (URL): http://<your_machinename>/output
      5. Click Ok
      6. Confirm that the service is running.
    4. Create an ArcMap Service from a sample *.MXD file.
        Map File: c:\test_9_win.mxd
        Virtual Server: ImageServerArcMap1
        Image Type: JPEG
      5. Click Ok
  • UNIX
    1. Download the UNIX Sample Data and Map Configuration Files (AXL and MXD) from the followng location: Download sampleunix.tar
      1. Navigate to the root tmp directory.
        cd /tmp
      2. Copy sampleunix.tar that was downloaded to a temporary location.
        cp <temp location of file>/sampleunix.tar sampleunix.tar
      3. Extract the contents of the file.
        tar -xvf sampleunix.tar
      1. Launch ArcIMS Administrator by navigating to: $AIMSHOME/bin and typing:
        ./aimsadmin
        Map File: /tmp/test_unix.axl
        Image Type: JPEG
        Directory Location: $HOME/arcgis/Output
      5. Click Ok
    4. For version 9.0.1 and above, create an ArcMap Service from a sample *.MXD file.
        ./aimsadmin
        Map File: /tmp/test_9_unix.mxd
        Image Type: JPEG
      5. Click OK.
      Warning:
      If any of the above tests fail to create a map service, please note the exact error code and message, and gather any additional information from the ArcIMS Message Console (Help > Administrator Message Console).
      Additional information on error messages can be found in the ArcIMS Help under: Getting Support and Troubleshooting > Error and Warning Messages Described.
      Contact ESRI Support and provide a detailed description of the error message.
Related Information
