BUG
When passing parameters through the URL, the HTML viewer will zoom to the desired line feature but the feature doesn't highlight.
This issue has been fixed in ArcIMS 9, but viewers that were originally created in ArcIMS 4.x and moved to a ArcIMS 9 server will still have this problem.
The highlight AXL is added in addSelectToMap() function in aimsSelect.js and sets the AXL text based on the selectType variable.
Because the variable is undefined when called with the start up parameters, it defaults to the polygon case, which doesn't highlight the line feature.
Code:
function addSelectToMap(){
Code:
selectType = LayerType[ActiveLayerIndex];
Code:
var selString = "";
Clear the browser cache to ensure that the new aimSelect.js file is being used.
Get help from ArcGIS experts
Download the Esri Support App
