English
Problem: Network Analyst: Directions window does not support multiple directions models
The Directions window uses a set of syntaxes to present directions. Users cannot currently modify the syntaxes to reflect local common practices in presenting directions.
Cause
This is a known limitation.
Solution or Workaround
Users cannot change the syntaxes to reflect local common practices in presenting directions. However, users can translate key words and strings based on the existing model. The localization package and documentation will be provided to ESRI International Distributors.
