Frequently asked question
Where are the extension state settings stored for ArcMap, ArcCatalog, ArcScene and ArcGlobe?
Answer
The extension states are stored in the following registry keys:
HKEY_CURRENT_USER\Software\ESRI\ArcCatalog\Extensions
HKEY_CURRENT_USER\Software\ESRI\ArcMap\Extensions
HKEY_CURRENT_USER\Software\ESRI\ArcScene\Extensions
HKEY_CURRENT_USER\Software\ESRI\ArcGlobe\Extensions
The name corresponds to the CLSID found in the ESRI MX Extensions, ESRI GX Extensions, ESRI SX Extensions and ESRI GMx Extensions.
The data value corresponds to the enumeration esriExtensionState. The
esriExtensionState Constants are as follows:
esriESEnabled - 1 - Enabled for use.
esriESDisabled - 2 - Disabled by the user.
esriESUnavailable - 4 - Unavailable - not licensed.
Warning:
It is not recommended that you modify these settings in the system registry directly. If you wish to change the Extension State use the application GUI or ArcObjects. ESRI cannot guarantee results from incorrect modifications.
Article ID:000007821
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
