BUG
Cannot change the network evaluator type for multiple rows using the inline dropdown list
On the Evaluators dialog of a network dataset attributes, it is possible to select multiple rows by holding the Ctrl or Shift keys while selecting. However, when using the inline dropdown list to specify the evaluator type, it does not change the evaluator type for all of the selected rows.
Cause
The inline dropdown list only changes the evaluator type for the rows that were selected when the dropdown list is opened. This can get complicated when multiple items are selected, as opening the dropdown list can change which rows are selected.
Workaround
When changing multiple evaluators simultaneously, it is easier to use the right-click context menu than the inline dropdown list.
  1. Select the rows to be changed.
  2. Right-click one of the selected rows and point to Type.
  3. Click the appropriate evaluator type for these rows.
Article ID:000007814
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
