ERROR
The index passed was not within the valid range
Last Published: August 20, 2021
Error Message
This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
The following error is returned when building a shapefile network dataset in ArcCatalog:
Error:
The index passed was not within the valid range.
Cause
The shapefile is corrupted due to an invalid precision.
Solution or Workaround
Re-create the shapefile.
Article ID:000007811
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
